1997 Buick Riviera Tune Up
RICKIEG97
Engine Performance problem
1997 Buick Riviera 6 cyl Front Wheel Drive Automatic
My Riviera is running a little sluggish. I changed plugs 50K ago. Any thing I can do to help the performance besides changing plugs, and any recommendation on the plugs. Its got 167K and doesn't burn oil. Thanks
Aug 30, 2010 at 5:39 AM
ERNEST CLARK
  • 1,730 POSTS
your plugs are due for a changed. But I'd go with iridium this time around. Also change the wires/boots, fuel and air filters. And have you ever changed the O2 sensors??? If not, they're due for a change. Even when the computer doesn't detect a problem with them, they still fall slightly out of range as they age, and the computer compensates for it, but at the cost of fuel economy ans sometimes overall performance.
With so many miles, it possible other engine components/sensors may need changing. But don't fix what ain't broke.
If your engine continues to run sluggish after the tune up, have the computer and sensors checked out.
Sep 26, 2010 at 2:48 AM
RICKIEG97
Thanks Ernest, Good information in your reply. I'm going to follow your advise. Appreciate it Rick
Sep 26, 2010 at 3:09 AM
