1996 Buick Riviera Uneven A/C
SANTANA
I have a 96 Riviera that when the air conditioning is on it is only coming out cold on the passenger and back seats and on the drivers left vents and the center vents it comes out basically about 75 degrees. Any suggestions on what part it may need? :(
Apr 13, 2006 at 6:19 AM
LOSONE
  • 1,616 POSTS
It sounds like you have a blend door malfunction. Somethime you have to replace the A/C controller. It also may be as simple as a vacuum hose under the dash.
Apr 14, 2006 at 5:13 AM
Suggested Repair
Check for a blend door malfunction, a failed A/C controller, or a disconnected or leaking vacuum hose under the dash.
Conversation Summary
The owner of a 1996 Buick Riviera reports cold air from the passenger and rear vents but about 75-degree air from the driver-side and center vents. The expert suggests a blend door malfunction, possible A/C controller replacement, or a vacuum hose problem under the dash.
