When I start the car, the idle jumps up to about 1700 RPMs and just slowly rises to about 2000. When I give it a little gas, it comes down a little. So I keep doing that until I get it to go down to about 900 so I can put it in gear without worrying about breaking a motor mount. But then the idle just starts to rise again. I pulled the trouble codes from it and got a code 22 (TPS voltage low). I unplugged the TPS (Throttle Position Sensor), started the car, and then checked the voltage of the circuit itself with my multimeter, getting a reading of exactly 5.0 volts. What should I be getting???
Mar 23, 2008 at 1:49 AM
