2007 Buick Rendezvous POWER FAILURE
45,000 MILES • 6 CYL • FWD • AUTOMATIC
JR1DARBY
periodiclly the vehicle wont start. It appears the battery does not have enough power. it will start with a jump. the dealer tested for a voltage draw but could not find one. the battery and alternator have been replaced (less than 2 years ago). dealer noticed some corrsion on the battery cable and cleaned that up, but problem happened 2 weeks later.
something is causing the vehicle to loose power when it sits overnight. it only happens periodically, and more often when it is a cold night.
dealer appears to be incompetent. I need your help.
Thank you for your consideration.
Apr 17, 2010 at 2:28 AM
KHLOW2008
  • 41,812 POSTS
Hi jr1darby,
Thank you for the donation.
Such problems are rather tricky and is not going to be easy to diagnose.
Quite often it is a sticking relay that causes intermittent drains on the battery.
Have you ever noticed any electrical components that does not shut off when the engnine is not running?
Apr 17, 2010 at 4:35 PM
JR1DARBY
Everything appears to turn off when car is not running.
this problem seems to happen in the cooler months and not in the summer.
Apr 18, 2010 at 5:12 AM
KHLOW2008
  • 41,812 POSTS
When problem occurs, is the battery completely drained or just weak?
Parasitic drains would normally get the battery flat and if it is only weakening the battery during colder weather, it could be the battery is the cause.
When did this problem start occuring?
Is your battery the maintenance free type?
Apr 19, 2010 at 12:37 AM
JR1DARBY
the battery is not completely dead; the interior lights all work. This has been happening for about 2 years. It is a maintenance free battery from the gm dealer. It is the 3rd battery. the car was at the dealer 2 weeks ago and they stated that the battery and alternator are fine.
Apr 19, 2010 at 12:49 AM
KHLOW2008
  • 41,812 POSTS
Maintenance free batteries are known to fail intermittently. They could be good one moment and the next you won't ba able to start the vehicle though all components works. It can work everything except the starter.
When the battery is good, testing would not showanything. I have encountered a few such cases.
Since the problem had been present since the battery was replaced, maybe you can try a swap of batteries with another vehicle to test if the problem goes away.
Apr 19, 2010 at 1:14 AM
