2006 Buick Rendezvous Egr valve
2006 BUICK RENDEZVOUS
25,000 MILES • 6 CYL • 2WD • AUTOMATIC
C.JOHNSON 1933
Engine light on. Had a teck look at it. Not a dealer.He replaced the egr valve. reflashed the computer. After I drove 10 miles the light came back on. when I take it back what should I suggest he do. This is not a cheap veture.
May 31, 2010 at 3:56 AM
  • 110,244 POSTS
First have them scan the computer to identify if the same code comes up for them.
Let me know what you find.
Jun 1, 2010 at 6:48 AM
C.JOHNSON 1933
I had the car back to the teck this AM. Had 2 code in the computer now. Teck went to the desk top computer & found the answer. The egr kit has wrong info for the wiring. There is a correction for this model buick. Changed the wires to correct wires & everything is OK now. Thank you for your response. Will hope I will not bother you again. I was concerned. TKS Again Chas. Johnson
Jun 1, 2010 at 2:16 PM
  • 110,244 POSTS
That makes sense. I'm glad it is fixed, but don't think you are a bother. We are here to help. I hope you have good luck now, but if there is a problem, let us know.
Jun 1, 2010 at 3:47 PM
