2002 Buick Rendezvous Traction System
JACQUELYNEMB
  • 2002 BUICK RENDEZVOUS
Tires and Wheels problem
2002 Buick Rendezvous 6 cyl Four Wheel Drive Automatic
I have a rubbing issue on the front driver side when I break and try to turn. My service traction system light comes on and sometimes my anit-lock break light comes on. How do I serivce the traction system or what do I need to do to stop the rubbing when I break and turn. Mainly happens when I try to turn right.
Monday, May 31st, 2010 AT 3:58 PM
FACTORYJACK
  • 4,159 POSTS
If the traction and ABS light are coming on, it is setting a code that would directly relate to a fault. It would require a scan tool to extract the codes, it would be a guess at this point as to what is causing it, there are many possibilities. There are a couple bulletins regarding front wheel bearing issues with your vehicle, and a special policy campaign if yours fits the criteria. Here is that info.
#06036A: Special Policy Adjustment - Front Wheel Bearing - (Jan 4, 2007)
Subject: 06036A -- SPECIAL POLICY ADJUSTMENT - FRONT WHEEL BEARING
Models: 2002-2004 BUICK RENDEZVOUS
2002-2004 PONTIAC AZTEK
The breakpoints for model year 2004 have been revised. Discard all copies of bulletin 06036, issued September 2006.
Condition
Some customers of 2002-2004 Buick Rendezvous and Pontiac Aztek vehicles may hear a hum, growl, or groan coming from the front wheels at speeds of 10 mph (16 km/h) or higher. The ABS telltale lamp in the I/P may also illuminate. This may be caused by premature wear of the front wheel bearing(s).
This special policy covers the replacement of front wheel bearings due to premature wear for a period of 5 years or 60,000 miles (100,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after September 1, 2006, are covered by this special policy and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to September 1, 2006, must be submitted to the Service Contract provider.
Vehicles Involved
Involved are certain 2002-2004 Buick Rendezvous and Pontiac Aztek vehicles built within the following VIN breakpoints:
Year
Division
Model
From
Through
2002
Buick
Rendezvous
2S500001
2S609116
2003
Buick
Rendezvous
3S500011
3S610198
2004
Buick
Rendezvous
4S500001
4S543332
2002
Pontiac
Aztek
2S500247
2S608952
2003
Pontiac
Aztek
3S500001
3S609928
2004
Pontiac
Aztek
4S500028
4S543350
Tuesday, June 1st, 2010 AT 12:47 AM
