2002 Buick Rendezvous DIFFERENTIAL NOISE - HOW TO CHANGE OI
2002 BUICK RENDEZVOUS
145,549 MILES • 6 CYL • 4WD • AUTOMATIC
ALL_BUICK
I have seen the statement - noise in differential - change oil with GM #.........
I have the oil
I have the car
I can't find the plugs
I have worked on cars for over 40 yrs - but I can't find the drain or fill port on the Rendezvous AWL Differential - any pictures or specific hole locations woiuld be appreciated.
Oct 19, 2008 at 8:42 AM
DENNYP
  • 1,824 POSTS
https://images.2carpros.com/forum/automotive_pictures/102900_diff_1.jpg
(1) Washer (2) Nut (3) Spacer (4) Bracket (5) Bolt (6) Bolt (7) Bolt (8) Torque Tube Assembly (9) Oil Seal (10) Bolt (11) Pinion and Housing Assembly (12) O-Ring (13) Shim (14) Oil Seal (Right) (15) Vent Hose Assembly (16) Clamp (17) Differential Assembly (18) Snap Ring (19) Axle Shaft (20) Snap Ring (21) Oil Seal (Left) (22) Fill Plug (23) Gasket (24) Drain Plug (25) Gasket (26) O-Ring (27) O-Ring (28) Clutch Pump Check Valve (29) Bolts
Oct 29, 2008 at 8:59 AM
