Bad Brakes???
BUICK REGAL
MAVRIK435
I have a 1983 Buick Regal Limited 4.1L V6 with 220,000 miles on it. The Engine runs great but the brakes are not working. I have replaced the Brake master cylinder and the brake booster and the brake pads and shoes. I have also bled the braking system like 10 times, but the brakes still won't work. I am desperate and cannot think of anything else please help me,what might the problem be? and how can I fix it? Please help. Thanks.
Mar 4, 2007 at 1:28 PM
KNIGHTRIDERKITT2000
  • 93 POSTS
are you losing brake fluid? do the calipers work?
Mar 4, 2007 at 5:21 PM
Did you adjust the brake booster pushrod?
Mar 4, 2007 at 5:36 PM
MAVRIK435
No I didn't know I had to ajust the brake booste pushrod, and how do I do that? also how do I check the brake calipers? and no I am not losing brake fluid.
Mar 5, 2007 at 4:26 AM
[quote:cc10729b37="Mavrik435"]No I didn't know I had to ajust the brake booste pushrod, and how do I do that? also how do I check the brake calipers? and no I am not losing brake fluid.[/quote:cc10729b37]
You need a book for the clearance ,follow the brake pedal to the firewall you'll see it there.
Also are you sure your wheel cylinders are not leaking and did you bleed the M/C.
Mar 5, 2007 at 6:12 AM
KNIGHTRIDERKITT2000
  • 93 POSTS
sorry mavrik, meant wheel cylinders (thanks Raz) Long day at work, couldnt think straight, too tired
Mar 5, 2007 at 1:05 PM
