2000 Buick Regal Ignition Switch?
90,888 MILES • 6 CYL • 2WD • AUTOMATIC
SLUEBKE
Thought I had a dead battery (weak/not cranking). After replacement, ALL Dash lights pulsating, when key cranked. Car not starting - when applyed e-brake and stepping on brake car would crank - car starts, then motor surges and stalls out when releasing e-brake, lights go back to pulsing. Went thru whole scenario, got car to run - then stopped at stop sign, applied turn signal and car stalls - dead now - back to pulsing lights until cranking all the way and evrything goes dead and won't start. I think it's ignition switch - where do I locate this? Under steering column (down by brake somewhere), or is it under horn/air bag assembly in steering wheel cover?
May 19, 2008 at 5:42 AM
DANIELLE_BOYD1620
[quote:3c9fbd7a7c="sluebke"]Electrical problem
2000 Buick Regal 6 cyl Two Wheel Drive Automatic 90,888 miles
Thought I had a dead battery (weak/not cranking). After replacement, ALL Dash lights pulsating, when key cranked. Car not starting - when applyed e-brake and stepping on brake car would crank - car starts, then motor surges and stalls out when releasing e-brake, lights go back to pulsing. Went thru whole scenario, got car to run - then stopped at stop sign, applied turn signal and car stalls - dead now - back to pulsing lights until cranking all the way and evrything goes dead and won't start. I think it's ignition switch - where do I locate this? Under steering column (down by brake somewhere), or is it under horn/air bag assembly in steering wheel cover?[/quote:3c9fbd7a7c]
regals are soo crappy. today i replaced my ignitoin switch it is very hard to take off wheel, but the switch is indeed behind the air bag, and behind the wheell
Jun 8, 2008 at 10:59 AM
