Right now it sounds like the battery or battery cables. I've seen intermittent no start caused by bad battery cables. The vehicle would always start with a boost. You might try cleaning both ends of the battery cables, see if it helps.
Any testing you do, needs to be done when the vehicle refuses to crank.
SPONSORED LINKS
Friday, June 6th, 2008 AT 12:43 PM
