1998 Buick Regal changing fuses
1998 BUICK REGAL
SHORTS.SABRINA
Electrical problem
1998 Buick Regal 6 cyl Two Wheel Drive Automatic
Recently i purchased a 98 regal. the problem im having with it is 1. i keep changing the door lock fuses because they short out every other week, 2. my gas guage doesnt work, #. the instrument panel lights up when it wants to. i cant even read the mileage on the car , or know what gear its in only if i look down at the gear shift. # 3. my trunk used to open now, it doesnt the key turns oneway but not the way to open it no trunk access at all. whats going wrong here?
Aug 20, 2010 at 3:12 AM
MERLIN2021
  • 17,250 POSTS
The first step in diagnosing today's cars, is to scan for codes, in your case you will need a good shop or the dealer to do it. B and U codes cant be read by most cheap hand help scanners. Scan to replace only what's needed, BCM(body control module) is a suspect here.
Aug 20, 2010 at 3:37 AM
