1989 Buick Regal Blinker system.......
TEX609
Electrical problem
1989 Buick Regal 6 cyl Two Wheel Drive
I had someone offer for me to fix a blinker system and i need to replace the blinker swivel switch on the column but hes stated that it has to be pulled out and flip'd up or down while holding it out to get the flashing blinkers to work for left or right and that he took it to a repair shop and they told him there will be wire damage, i dont know but probably to get more money from him but i was trying to get a round about visual on the problem if you might be able to help thats all the infornmation i know about it thanx.
May 26, 2008 at 6:07 AM
BLACKOP555
  • 10,386 POSTS
well, i would first get the switch froma junk vehicle in a junk yard to save a bit of money, and then install it if it works good, if not it may be wiring.
you need to replace the part anyways so replace it and go from there.
i doubt its wire damage sounds like a bad swithc.
May 26, 2008 at 8:19 AM
