2003 Buick Regal Shift Indicator Light
TONY4321
Help
Buick Regal LS 2003 58,000 miles
My buick regal shift indicator light on the center console went out. I brought the car to the Buick repair center. They told me there is no indicator light on the center console shift unit in the books for a 2003 Regal LS.
The only shift indicator is on the dash.
I have told them it always light up since I bought it. and dimmed with the interior light switch for the console.
Is there a part number for the Light or is it part of the shift unit ?
Jun 14, 2006 at 1:14 PM
T DAWG
  • 6 POSTS
I have owned car since new, and there is no light present in the location described.
Feb 14, 2010 at 5:21 PM
DANAUTHIER
  • 156 POSTS
My Database does show a lamp in the floor shift model of the 03 Regal LS wiring diagram. Unfortunately, it does not state if the bulb is replaceable or not, and if it is replaceable, what bulb it is.
I can tell you that in my experience, the most common lamps used to illuminate the floor shift indicator are #24 and #194. and they are available at any autoparts store and most department store with an automotive section.The only way I can tell you is to open up the shifter and look to see what bulb is in there.
Sorry I can not provide any more information than that.
Let me know if it helps.
Dan
Feb 14, 2010 at 5:55 PM
Suggested Repair
Open the floor shifter and inspect the indicator lamp. Common bulbs used for this light are #24 and #194, available at auto parts stores. The wiring diagram shows a lamp, but it does not confirm whether the bulb is replaceable.
Conversation Summary
The owner of a 2003 Buick Regal LS says the center console shift indicator light went out and dimmed with the interior lights, but the dealer said no such light is listed and only the dash indicator exists. Another owner reported no light in that location. An expert notes the floor-shift wiring diagram includes a lamp but does not identify a replaceable bulb; common possibilities are #24 and #194, so the shifter must be opened to check.
