I drive a 1994 Buick Park Avenue, and recently my windshield wipers stopped working. I removed the windshield vent and saw that the wiper motor crank arm had disconnected from the linkage unit. I changed the wiper motor AND the linkage. After replacing these parts, Inoticed every time the motor rotated, the linkage would slip off the crank arm. I took the cover off the motor and now the motor will not fully rotate. On the inside of the cover, it has two arrows pointing to where the drive pin should be, it also says "position properly". Could this be my problem, b/c I don't know what "position properly" means.
May 2, 2007 at 11:44 PM
