2000 Buick Park Avenue brakes pulsates when braking at high
2000 BUICK PARK AVENUE
PENNSTATEFAN
Brakes problem
2000 Buick Park Avenue Two Wheel Drive Automatic 130000 miles
The brakes pulsates when braking at higher speeds. The brakes don't puslsates are bad after I replaced the rear rotors...they were pitted. The front rotors look fine.
I can also fell a little vibration in the steering wheel when I reach speeds of 60 and up. I recently had new tire installed along with an alignment. Additionally, I had a bad tie rod end replaced as well.
After all of that, the car ride did improve. however, after all of that, I still can feel the vibration. It's just not as strong.
Aug 11, 2010 at 4:00 PM
Mike them rotors all around for warpage, Eyeballing its not that good, the micrometer and dial indicator will tell the tale.
Aug 11, 2010 at 4:12 PM
PENNSTATEFAN
Ok...Thanks
Aug 12, 2010 at 2:09 PM
