1999 Buick Park Avenue
MRDJ1943
  • 1999 BUICK PARK AVENUE
Engine Performance problem
1999 Buick Park Avenue 6 cyl Front Wheel Drive Automatic
Our '99 Buick Park Avenue (155k miles) cut off last night and won't restart. It has a faulty gas gauge, so we added 4 gallons of gas just in case. It still won't restart, but the engine turns over. We couldn't hear the fuel pump when the ignition key was turned on. We're having the car towed home in a few minutes. Do you have any suggestions about what to check?
Wednesday, July 7th, 2010 AT 11:12 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.I would check what the fuel pressure is you can rent a fuel pressure gauge at auto zone.I would also check for spark and see if you can rent a scan tool to check for code's let me know what you find.
Thursday, July 8th, 2010 AT 12:03 AM
MRDJ1943
I don't have a fuel pressure gauge, but there seems to be some pressure at the fuel rail. I checked for codes with a scanner and found none. The fuel pump doesn't seem to make any noise when the ignition is turned on.
Thursday, July 8th, 2010 AT 4:27 AM
SATURNTECH9
  • 30,869 POSTS
Can you rent a fuel pressure gauge from auto zone or some where that rent's them?You could have fuel at the rail like your saying but it might only be 5psi which won't start the car. We need to see what we have and don't have so we can figure out why your car doesn't run. Also did you check for spark like I asked?If so do you have spark?
Thursday, July 8th, 2010 AT 1:14 PM
