1998 Buick Park Avenue wont blow cold air on passanger side
1998 BUICK PARK AVENUE
210,000 MILES • V8 • 2WD • AUTOMATIC
ABRAMSTRUCK
blows hot air out passenger side and cold on drivers side? any suggestions
Jul 12, 2010 at 12:56 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
If you have dual climate control, there are two seperate blend air doors that determine if you get heat or AC. Check them and let me know what you find. NOTE: They are under the dash near the heater core.
Jul 23, 2010 at 11:09 PM
REALCOOLGUY
The problem is when the A/C is just a little low the air on the driver side is still cold while the passenger side will be warm. Charging the A/C until the passenger side becomes cool/cold is the solution here. However be careful not to go too far and overcharge which can damage the system.
Aug 18, 2010 at 4:04 PM
