Fuse box location fuse for cigarette lighter?
TBGREE
  • 2004 BUICK PARK AVENUE
  • 101,000 MILES
I need the fuse for cigarette lighter?
Saturday, April 14th, 2012 AT 7:45 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,348 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Wednesday, July 10th, 2019 AT 9:43 PM
LISAACREE
  • 1999 BUICK PARK AVENUE
  • 6 CYL
  • FWD
Where is the fuse panel for cigarette lighter?
Friday, February 5th, 2021 AT 9:48 AM (Merged)
KEN L
  • 54,348 POSTS
Hey,
Here is the fuse panel for you car. One is located on the drivers side under the dash and the other under the passenger's side.
1 - Not Used
2 - Not Used
3 - Power Seats Circuit Breaker
4 - Not Used
5 - Not Used
1A - PASS Key
2A - Spare
3A - Not Used
4A - Not Used
5A - Auto HVAC, ALM, Cruise Control, Cluster
6A - Courtesy Lamps, Power Mirrors
7A - Not Used
8A - Perimeter Lighting
9A - Not Used
1B - Turn Signal, Back-Up Lamps, BTSI
2B - Spare
3B - Not Used
4B - Not Used
5B - Anti-Lock Brake System, Computer Command Control
6B - Brake and Hazard Lamps
7B - Not Used
8B - Interior Lighting
9B - Cigarette Lighter
1C - Air Bag System
2C - Spare
3C - Not Used
4C - Not Used
5C - Cooling Fans, Transaxle
6C - Parking Lamps, Interior Lamps
7C - Not Used
8C - Parking Lamps
9C - Radio, Cluster
1D - Telltale, Chime, Cluster, RAC, LCM
2D - Spare
3D - Heated Mirrors
4D - Not Used
5D - Manual A/C
6D - Not Used
7D - TCC
8D - Radio
9D - Not Used
1E - Not Used
2E - Air Bag System, PASS-Key
3E - Not Used
4E - Not Used
5E - Rear Defog
6E - Not Used
7E - Miscellaneous Engine-Non OBDII
8E - Wipers, Washer*
9E - Not Used
and
1 - Door Locks
2 - Trunk Release, RAC
3 - Horns
4 - Not Used
5 - Miscellaneous Engine Controls (OBD II)
6 - Fuel Pump
7 - Injectors
8 - Powertrain Control Module
9 - Not Used
10 - Not Used
11 - A/C Programmer
12 - Not Used
Please use 2Carpros. Com any time
Best, Ken
CHRISPITMAN
  • 10 POSTS
  • 1998 BUICK PARK AVENUE
  • 6 CYL
  • FWD
  • 200,000 MILES
Where is the fuse fuse box under the instrument panel/ dashboard? Buick couldn't tell me nor the dealer.
Hi chrispitman,Welcome to 2carpros
Underhood Junction Block -Locations
RH Front Of The Engine Compartment
https://www.2carpros.com/forum/automotive_pictures/12900_f1_22.jpg
RH Of The Engine Compartment
https://www.2carpros.com/forum/automotive_pictures/12900_f2_22.jpg
IP Junction Block -Locations
Behind The RH Of The Instrument Panel
https://www.2carpros.com/forum/automotive_pictures/12900_f3_11.jpg
Rear Junction Block
Under The Rear Seat
https://www.2carpros.com/forum/automotive_pictures/12900_f4_6.jpg
Center right hand rear of the passenger compartment, under the rear seat cushion
DARCYRAE
  • 1997 BUICK PARK AVENUE
  • 6 CYL
  • FWD
  • 100,000 MILES
My car doors will not unlock in the rear of my car from the inside or the out. And would like too know where the fuse box is located on this car? Thank you your help
DOCFIXIT
  • 18,828 POSTS
There are three under pass side dash
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_104.jpg
Underhood
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_393.jpg
Trunk
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_4_24.jpg
ZZACK11
  • 6 CYL
  • FWD
  • 79,000 MILES
Ac does not turn on. Is Blowing air, No Compressor Click when turn on, underhood fuses and relays good, but can't find under dash fuse panel to check status of the AC fuse there. Removed the hush panel on the driver side and a panel on passenger side. Where ever it is, It should not be this difficult to access. Have checked rear seat fuse panel too.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny
here is the information you requested for the fuse and fuse block locations relating to the ac fuses. Here is a tutorial for you to view on how to test and replace a fuses.
I've attached the fuse block location below and circled all the related ac-hvac fuse locations and circled in red for your Buick. Hope this helps and thanks for using 2CarPros.
BOSSLADY
  • BUICK PARK AVENUE
Where is the fuse box located on a 97 buick park avenue - supercharged
KEN L
  • 54,348 POSTS
Here is the fuse box and relay box to help you get the problem fixed. Diagrams below:
1 - Circuit Breaker - Power Windows, Sunroof
2 - Not Used
3 - Circuit Breaker - Power Seats
4 - Not Used
5 - Not Used
1A - PASS-Key II
2A - Spare
3A - Not Used
4A - Not Used
5A - Ignition (Run), Automatic A/C Control, Cruise, Base Cluster
6A - Courtesy Lights, Power Mirrors, Memory Seat Switch
7A - Not Used
8A - Not Used
9A - Cigar Lighter
1B - Turn Signal, Back-Up Lights, Cornering Lights, Brake-Transaxle Shift Interlock
2B - Spare
3B - Not Used
4B - Not Used
5B - Anti-Lock Brake System, Firm Ride
6B - Brake & Hazard Lamps
7B - Not Used
8B - Interior Lamps
9B - Level Control
1C - Air Bag
2C - Spare
3C - Not Used
4C - Not Used
5C - Cooling Fan, Transaxle
6C - Parking Lamps
7C - Not Used
8C - Not Used
9C - Radio, Cluster, Battery
1D - Ignition (Run/Crank), Chime, Cluster
2D - Spare
3D - Heated Mirror
4D - Not Used
5D - Base A/C
6D - Fog Lamps
7D - Not Used
8D - Radio
9D - Not Used
1E - Auxiliary Outlet
2E - Air Bag, PASS-Key
3E - Ignition (Off/Unlock)
4E - Not Used
5E - Rear Defog
6E - Not Used
7E - Not Used
8E - Wipers, Washer
9E - Not Used
Relay box
1 - Door Locks, Trunk Pull Down, Fuel Door Release
2 - Power Antenna, Trunk Release
3 - Horns
4 - Not Used
5 - Misc. Engine Controls
6 - Fuel Pump
7 - Injectors
9 - Not Used
10 - Not Used
11 - A/C Programmer
12 - Not Used
This is a mid year split so you can one of two systems here are both in the diagrams below.
