1996 Buick Park Avenue fuse
1996 BUICK PARK AVENUE
135,000 MILES • 6 CYL • FWD • AUTOMATIC
JUNIOR WILCOX
the fuse for fuel injectors will blow when going down road or setting with mortor running...
Oct 10, 2009 at 7:02 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
I hate to say it, but you need to start at the injectors one at a time, start the car, and try wiggeling the wires from each one until if blows the fuse. Chances are there is a short within 4 inches of the injector itself caused by heat from the engine. IF that doesn't pop the fuse, you will need to check for continunity between each of the injectors and the computer to see if there is too much resistance in one.
Let me know what you find.
Oct 11, 2009 at 9:24 PM
