1996 Buick Park Avenue
GARY5740
  • 1996 BUICK PARK AVENUE
  • 6 CYL
  • FWD
  • 75,120 MILES
I am hearing dull clunk coming from the floorboard area under hard acceleration it is a double clunk (up and down motion of the car)
I am guessing sway bar links or bushings, what is your thought. The struts were replaced at 55,000 miles
Saturday, January 30th, 2010 AT 11:03 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check motor mounts engine maybe moving under torque and exhaust hiting floor.
Let me know
Thanks for donate
Saturday, January 30th, 2010 AT 1:06 PM
GARY5740
  • 14 POSTS
It does not make this noise if I brake torque the engine do you still suspect mounts?
Saturday, January 30th, 2010 AT 2:45 PM
DOCFIXIT
  • 18,828 POSTS
Does engine move up as if not attached to frame? Have you looked at sway bar mounts? Sway bar is under pressure during turns not straight acceleration. Noise from pass side? Any noise under hard braking?
Sunday, January 31st, 2010 AT 2:07 PM
GARY5740
  • 14 POSTS
The front of the engine moves up about 1/2" under hard brake torque no noise-the noise appears to come from passenger side floor board area, does not make noise under braking have not checked sway bar links or bushings
Monday, February 1st, 2010 AT 3:21 PM
