1992 Buick Park Avenue gas smell
1992 BUICK PARK AVENUE
BABIESBABY
Smells problem
1992 Buick Park Avenue 6 cyl Front Wheel Drive Automatic
what would cause a car to smell like gas when there is no visable leak. it smells really bad when the heater is on.
Sep 22, 2010 at 7:12 AM
ERNEST CLARK
  • 1,730 POSTS
First of all, this is a very dangerous situation. Fumes can kill you. You should stop driving your car until you identify the source of these fumes.
It's possible your fuel pressure regulator is leaking fuel. You can pull the vacuum hose that connects to the FPR and smell for fuel. Sometimes they will leak.
Next check all the fuel lines/filter for wetness. Finally, check the exhaust system for leaks (including the catalytic converter).
Sep 26, 2010 at 4:55 AM
