1992 Buick Park Avenue COMPRESSOR NOT COMING ON
1992 BUICK PARK AVENUE
LLINDASM1947
Air Conditioning problem
1992 Buick Park Avenue 6 cyl Front Wheel Drive Automatic
WHAT SHOULD I CHECK IF COMPRESSOR NOT COMING ON
Jul 31, 2008 at 6:31 PM
  • CERTIFIED EXPERT
  • 31,937 POSTS
Hi there,
I would first check any fuse that may be blown and failing that have a small charge of refrigerant with a leak detector dye added and do a leak test.
Mark (mhpautos)
Jul 31, 2008 at 6:35 PM
  • CERTIFIED EXPERT
Have the pressures checked-could be low on freon
LLINDASM1947
  • 0 POST
I think my problem is the dash switch isn't sending 12 volts to the compressor. Fuses are all good.
Jan 13, 2023 at 1:16 PM
