I have replaced the thermostat, a bypass hose, put stop leak in system and topped off anti-freeze. The heat comes on intermitinley and the temp guage registers higher than normal.
Am I missing something obvious? There are no visible signs of leakage, and the oil looks pretty good.
Any help would be appriciated
Thanks
SPONSORED LINKS
Wednesday, February 4th, 2009 AT 10:49 PM
SNAPONADDICT
MEMBER
There is a air bleeding procedure for the cooling system on that car if you did not do this air could be trapped in the heater core there could be bigger problems I need more info on why you changed the thermostat
SPONSORED LINKS
Wednesday, February 4th, 2009 AT 11:17 PM
MURPH128
MEMBER
I replaced the T-stat because that seemed like a logical, cheap option. I am an armchair mechanic at best. How does one blled the air from the system?
