1990 Buick Park Avenue starts&dies
LEDGER1961
  • 1990 BUICK PARK AVENUE
  • 6 CYL
  • FWD
  • 197 MILES
I was going on a 25 miles per hour road for about 5 miles it started acting like it was out of gas so I stopped for about an hour & started it again & it ran good. This morning I went out to start it & it will start & die. Where should I begin?
Monday, August 31st, 2009 AT 11:01 AM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Monday, August 31st, 2009 AT 3:26 PM
Related General Content
