1998 Buick LeSabre MAP Sensor High
1998 BUICK
ACE101562
98 lesebre limited 90,000 3.8L code p0108=manifold absolute pressure/baro sensor high input. 0= generic 1= fuel and air metering 08=what system is malfunctioning. what system does 08 stand for and what procedures must I perform to find out the exact problem
Apr 12, 2007 at 8:10 AM
MERLIN2021
  • 17,250 POSTS
P0108 Manifold Absolute Pressure [MAP] Sensor Circuit High Voltage If you have a vacuum guage hook it up and see if the readings change when you apply vacuum. You may need a new MAP sensor The 1 denotes air fuel in your case since it's the map your looking at air or manifold pressure, so it either a bad sensor or a manifold air leak.
Apr 17, 2007 at 4:06 AM
Suggested Repair
Connect a vacuum gauge and confirm the reading changes when vacuum is applied. P0108 indicates a MAP sensor circuit high voltage; suspect a failed MAP sensor or a manifold air leak.
Conversation Summary
The owner of a 1998 Buick LeSabre Limited with a 3.8L engine asked what P0108 means and how to diagnose it. The expert explained that it is a MAP sensor circuit high-voltage code related to air/fuel metering and manifold pressure, and recommended checking vacuum response. Likely causes are a bad MAP sensor or a manifold air leak.
