2000 Buick Lesabre 2000 Buick Lesabre stalls without any no
WFRUTCHEY
  • 2000 BUICK LESABRE
  • 6 CYL
  • 103,000 MILES
I have a 2000 Lesabre that stalls while driving or idling (It just shuts off with out a sign) I had the ignition control modual tested and even tried another from the local scrapyard. I cleaned the air flow sensor and replaced the fuel pump. It still stalls. My local mechanic cant figure it out. Thinking maybe a crank or cam sensor. Can anyone help. Any help would be great. Please help
Tuesday, November 17th, 2009 AT 11:47 AM
  • 109,755 POSTS
The crank sensor could be the problem. Has the check engine light come on when this happens?
Monday, November 23rd, 2009 AT 9:37 AM
WFRUTCHEY
The check engine light is not on. It does go on when it stalls. It stalled this morning twice then I unpluged the air flow sensor plug and it has not stalled yet. Of course the check engine light is on now. Have you ever had a air flow sensor short out or go bad? Thanks for your help I gotta figure this out asap. Bill
Monday, November 23rd, 2009 AT 9:51 AM
RMK01289
Which air flow sensor did you unplug? My 97 lesabre is doing the same thing and I have replaced the fuel pump and coil pack and the stalling s just getting worse.
Tuesday, January 12th, 2010 AT 10:14 AM
