1997 Buick Lesabre 6 cyl Front Wheel Drive Automatic
I am a novice mechanic at best. I recently purchased a 1997 Buick LeSabre a few months ago. When I first got the vehicle I noticed the fuel pump had a loud "hum" to it. I was assured that this was not a big deal, but if I start having issues with the car sputerring I should have it replaced. I started noticing the car sputerring and when this happened I noticed the votage meter would drop lights would dim. When I tapped the gas the lights came back and the voltage went up. I had the fuel pump replaced and a few days later the voltage was dropping again and if I didn't tap the gas my car would stall as I was going down the road. I would have to put it in park and and turn the key. She starts everytime. I had the battery tested at my local parts store. They said my battery was extremely overcharged. It was reading 1495 when it is supposed to read 800. He suggested I replace the alternator as the voltage regulator inside was most likely bad, which I did. However it still hasn't resolved the problem. What could it possibly be?
SPONSORED LINKS
Friday, October 10th, 2008 AT 10:21 AM
