Leak of about a half gallon a day:
Mechanic replaced plastic upper intake with a junkyard part (been told this is probably bad as well)
He replaced intake manifold gaskets
We have replaced radiator cap and put in the $30 Bar's Leak Head Gasket Repair copper looking fluid. We also replaced the t-stat and t-stat gasket.
We are looking into buying a new upper intake and replacing ourselves. Sorry, I will post today after work about heater hose temps. When heater is running now it will cycle from 90 degrees to cool air where before it would blow 90 all the time. 85 and below blows cool air 100% of the time. Also, engine runs rough now and oil pressure is low (just above red).
P.S. I donated more money and I will donate more if necessary. Thank you for the help.
Monday, January 11th, 2010 AT 11:39 AM
