1995 Buick Lesabre fuel system problems
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
CMCOOK35
my car just died a couple of times in the road if i let it sit for a bit it would crank right up and then finally i wouldn't crank anymore it would however turn over since then i have put a new fuel filter in and a new fuel pump and it is still not cranking but still turns over so please do u have any ideas on what i should try next i know don't have much money because i spent it on the fuel pump what money i did have can u please give me some good advice what to do next please.
Jan 24, 2008 at 9:54 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9efe761222="cmcook35"]Other Category problem
1995 Buick Lesabre 6 cyl Two Wheel Drive Automatic 175000 miles
my car just died a couple of times in the road if i let it sit for a bit it would crank right up and then finally i wouldn't crank anymore it would however turn over since then i have put a new fuel filter in and a new fuel pump and it is still not cranking but still turns over so please do u have any ideas on what i should try next i know don't have much money because i spent it on the fuel pump what money i did have can u please give me some good advice what to do next please.[/quote:9efe761222]
check if you have spark and check crank sensor and module
Jan 27, 2008 at 7:23 AM
