1995 Buick Lesabre
JENNININE28
1995 Buick Lesabre 6 cyl Automatic 170000 miles
my buick has to be cranked about 60 times every morning before it will stay started....when it finally does start it dies everytime the transmission shifts into the next gear.if i drive it a little while it act better as time goes by. ive put it in the shop twice and even installed a remote start to bypass the vats security system. im at my wits end with this car.....i really need advise!!!!
thanks so much jenny
Sep 11, 2009 at 8:08 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I start by using a gage and checking fuel pressure. If there are no codes or anything to point you in the correct direction, I start with the basics, check for spark at the plugs and proper fuel pressure.
Sep 11, 2009 at 9:08 AM
JENNININE28
thank you i will try that
Sep 11, 2009 at 11:44 AM
