1994 Buick Lesabre Turn signal switch
1994 BUICK LESABRE
97,800 MILES • 6 CYL • 2WD • AUTOMATIC
DIYSPEN
I need to replace the turn signal switch I believe. Something 'snapped' and it no longer stays in the up - right hand turn position. Left hand signal still works. I know I need to remove steering wheel and column cover. Can you provide more specific detail of tools needed and will replacing the switch be obvious once I have access to it? I believe there is a plug in at the dash board.
Oct 15, 2009 at 9:07 AM
MICKEY-D
  • CAR REPAIR CONTRIBUTOR
  • 304 POSTS
You really should pick up a repair manual, it will tell you how, and what tools are needed. You will need a steering wheel puller, and a toll to push down the steel plate that locks the steering wheel when it's in park. A round steel clip holds the plate down,remove , and the turn switch is right there. mickey-d
Dec 7, 2009 at 12:06 PM
