1992 Buick Lesabre
LISA2862K
  • 1992 BUICK LESABRE
  • 6 CYL
  • FWD
  • 163,000 MILES
I replaced my cars fuel sending unit and now the car won't stay running
Saturday, October 31st, 2009 AT 8:37 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd use a fuel pressure gage and check fuel pressure. Also, check for any possible codes? Are you saying, you think there is an issue with the pump? There should be a fuel pump test connector, close to the battery, red wire with electrical connector, nothing plugged into it. If you use a jumper wire from battery voltage to connector, the pump should run. You don't have to use the key. Use an inline fuse on the jumper.
Saturday, October 31st, 2009 AT 11:22 AM
