2005 Buick LaCrosse Oil Consumption
LARRYB2280
I have a 2005 Buick LaCrosse with slightly over 17,000 miles which I bought new. It is equipped with the 3.8L V6 engine. Since it was new, it has used approximately 1/2 quart of oil per 1000 miles, and I have the oil changed every 3000 miles. I mentioned it at the first oil change, because the low oil level indicator came on. The dealer said that the oil pan was defective, ordered a new one, and replaced it at 4000 miles under warranty. Since there was no evidence of leakage I was sceptical of their diagnosis. The car doesn't leak, or smoke, but it continues to use oil at the same rate, and has done this consistently in the two years that I have driven it.
When I bring this up to the dealer, they want to perform an oil consumption test, which means that I have to bring the car in every 300 miles so they can record the consumption, which would be very inconvenient for me. Trust me, the car loses 1/2 quart of oil every 1000 miles, and I know this for a fact because I have to add a quart 2000 miles after my oil change.
All that being said, how do I get the attention of GM regarding this issue. I have had other GM vehicals with the same engine, and have never had an oil consumption problem. It doesn't make me want to hang on to the car past the warranty period.
May 1, 2007 at 5:58 AM
LSUSSEL
  • 252 POSTS
You can email GM at www.gm.com or get there contact info on their site as well, just a thought, the dealer may be using to cheap of an oil. I have heard of this type of issue before and it was cheap oil.
hope this helps.
May 9, 2007 at 5:16 PM
JAMES ANDERSON
  • 6 POSTS
These 3.8s do seem to have a problem with oil consumption.Ihave personally fixed many of them by,checking the lower intake,if no leaks are visible,then simply replace the PCV valve.These are very inexpensive,like 1-4dollars and generally will fix the oil consumption on the 3.8 engines.If you keep these replaced at regular intervals on these engines it should fix this problems.Try it out and contact me at janderson0574@hotmail.com or if you have questions on locating it I will be happy to guide youalso!
Dec 20, 2007 at 2:02 AM
Suggested Repair
Check the lower intake for leaks. If none are visible, replace the inexpensive PCV valve, and replace it at regular intervals. Also consider whether a low-quality oil is contributing, and contact GM if the consumption continues.
Conversation Summary
The owner of a low-mileage 2005 Buick LaCrosse with a 3.8L V6 reports consistent oil use of about 1/2 quart per 1,000 miles with no leaks or smoke. A dealer replaced the oil pan under warranty and later wanted a consumption test. One reply suggested contacting GM and questioned cheap oil. Another said these 3.8 engines often consume oil and recommended checking the lower intake, then replacing the PCV valve.
