You have to see if the air pump is working first, you have to use a scan tool that can command the air pump on/off to see if it works.A code like this is hard to answer, it code be a number of things, from a blown fuse to a bad relay or a bad air pump, even a blocked hose to the air pump.
SPONSORED LINKS
Sunday, June 15th, 2008 AT 7:58 PM
