1961 Buick Electra fuel tank
LIBERTYREVED
Engine Performance problem
1961 Buick Electra V8 Two Wheel Drive
What is a good way to drain old fuel from a 1960 Buick Electra gas tank? Is there a drain plug? If not...help!
Nov 5, 2009 at 12:21 AM
HMAC300
  • 48,601 POSTS
by all means do this outside, especially wher eyou have somplace to wash away any spilled gas. I fyou have a hydraulic jack that is better. remove the fuel line connections, put he jack under the tank an djust put some pressure on it. it's easier ifyou have some help. then remove the bolts to the straps an dlet the jack down. You'll have to maybe move it forward due to the filler neck. thn just puor the gas out the filler neck. Of course into a suitable container, then flush it with water first. BY NO MEANS USE ANY TYPE OF OPEN FLAME DUE TO THE EXSPLOSIVENESS OF GASOLINE!!!!!!!
Jan 10, 2010 at 7:06 AM
