Fuel filter
1986 BUICK CENTURY
DESS
  • 5 POSTS
Where in the world do you find the fuel filter in my car that is listed above. It is a v6 2.8, carburetor not injected. Please please help. Any one else have problems with mysterious shutting off problems? :(
Jul 16, 2006 at 5:06 PM
MIKEYBDMAN
  • CERTIFIED EXPERT
  • 623 POSTS
I am not 100% sure, but it looks like the fuel filter is inside the fuel tank. Sounds like it may be located on the sending unit/pump in the tank.
Jul 16, 2006 at 5:38 PM
DESS
  • 5 POSTS
I found one thing that said that it was just below the carburetor or under the pass seat and I forgot the rest, but I cannot find that article again. It said the injected kind is in the fuel tank.
Jul 16, 2006 at 5:41 PM
XOWEY
  • 113 POSTS
This is a 2.8 with a carburetor? I cannot remember an 1986 with this combination.
Well, if it has a carburetor. It should be a varijet. The filter is in the inlet to the carburetor.
Jul 17, 2006 at 3:20 PM
DESS
  • 5 POSTS
Okay thank you. It is a 1986 Buick century custom that has a carburetor.
Jul 17, 2006 at 4:29 PM
DESS
  • 5 POSTS
I found out it is in the carburetor. I am still having mysterious shutting off problems even after I brought it to the dealer to work on it. If any one could help I cannot find the flasher for the blinkers.
Jan 9, 2007 at 5:39 PM
ROBERT BELLE-ISLE
I know these posts were forever ago, but I have this exact same car with this exact same problem. Just wondering if you had any breakthroughs.
May 15, 2018 at 9:15 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
We need to see if you have spark when the engine stalls so we can determine if it is fuel or ignition related.
Here is a guide to help you check for spark look toward the bottom of the guide:
Cheers, Ken
May 15, 2018 at 11:52 AM
