low tire light?
2003 BUICK CENTURY
BENTON
the inflation pressure is has been corrected on all tires. How do you reset the "low tire light"
Dec 1, 2007 at 7:40 AM
TECH1
Inside the passenger side fuse block, there is a red 'reset' button. With the key in the on position, press and hold the button until the light on the dash goes out. The passenger side fuse block is gained through pulling the cover on the far passenger side of dash in the door opening area.
Jun 23, 2018 at 7:31 AM
BEVDIRKIN
Six cylinder front wheel drive automatic 77,000 miles.
How do i reset the low tire light? I had a flat tire and the light gave me a warning. Now it needs to be reset and i tried the reset button on the fuse panel, but it did not take care of this.
Jun 11, 2020 at 6:53 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
Adjust all tire pressures to the recommended 30 psi.
Turn on the ignition, with the engine off.
Press and hold the red reset button located in the passenger side instrument panel fuse block.
The low tire indicator will flash three times, then turn off.
After resetting, the TPM system requires up to thirty minutes of straight line driving in each of the three speed ranges to complete the calibration process.
BONNIE RICHARDSON
Electrical problem
2002 Buick Century Front Wheel Drive Automatic 58K miles
After tires have been properly inflated the "low tire" light staying on
DOCFIXIT
  • 18,828 POSTS
The pressure monitor in that tire maybe faulty.
CASSIE198
16,000 miles
My low tire light came on in my car listed above )Limited model). I put air in all of my tires and the ' low tire' light has not gone off. How do I turn it off?
  • 110,244 POSTS
The light will go off by itself it is a real time system you have a tire pressure sensor that is not working by chance you change a tire out lately? This would be the tire I would suspect.
Cheers, Joe
BOBANDLINDA
2000 Buick Century 6 cyl
All of my tires are properly inflated and the low tire light will not go out. We do not haver a maual. How do we turn it off?
CHARLIE4994
I just did this a week ago and as you I do not have a manual. Okay on the passenger side of the driver open the door. Their is a fuse box on the side of the dash. Open that up and their is a red reset button. Now turn on your vehicle and press the reset button until the low tire indicator go off.
That should do it. I have not had a problem since then.
RLELEN
2000 Buick Century 6 cyl Automatic 33000 miles
low tire light stays on
DOCFIXIT
  • 18,828 POSTS
Faulty sensor in wheel.
Jun 11, 2020 at 6:54 AM (Merged)
AZHOMBRE
  • 6 POSTS
Mine stayed on, so I went to discount tires and the service attendant came and pulled the fuse panel off the right side of the dash and held the button in for a few seconds and the light went out. He showed me how to do it, that is why I know! I would check this first before replacing the wheel sensor.
Tire pressure should be the same in all tires before resetting the switch in the fuse panel.
B_KRIVAK
I have a 2000 Buick Century Limited edition. The low tire pressure light came on. I had the tire pressure checked and they are fine. How do I reset the tire pressure light to get it to go off ? Auto zone told me there was some kind of code or something that I had that had to be put into the car to get it to go out.
Thank you,
Bab Krivak
AZHOMBRE
  • 6 POSTS
[quote:c9637cd21d="b_krivak"]Computer problem
2000 Buick Century 6 cyl Front Wheel Drive Automatic 56245 miles
Thank you,
Bab Krivak[/quote:c9637cd21d]
Pull the fuse panel located on the passenger side of the dash. There is a reset button that you hold in for a few seconds and the light will go out. Auto zone doesn't know what they are talking about! Mine came on and I took it to Discount tires and they did it for me, and showed me how to fix the problem. Make sure the air pressure is the same in alll tires first.
If this doesn't work, you have a bad wheel sensor
