There is no way to disable the alarm on your vehicle ? the vehicle will have to be plugged into a computer with the TECH2 software to discover the fault in your RCDLR ... You can however personalize your system with the following steps to disable the exterior light operation for the time being ??
Vehicle Personalization
Modes of Operation
Automatic Door Locks
The following are the modes of operation for the automatic door locks feature:
Mode 1:
The automatic door locks feature is disabled.
Mode 2:
All of the doors lock when the vehicle is shifted out of PARK with the ignition ON.
Mode 3: Default
All of the doors lock when the vehicle is shifted out of PARK with the ignition ON. All of the doors unlock when the vehicle is shifted into PARK.
Mode 4:
All of the doors lock when the vehicle is shifted out of PARK with the ignition ON. Only the driver door unlocks when the vehicle is shifted into PARK.
Delayed Locking
The following are the modes of operation for the delayed locking feature:
Mode 1:
All of the doors lock 5 seconds after the last door is closed when the lock switch is activated.
Mode 2: Default
The delayed locking feature is disabled.
Perimeter Lighting
The following are the modes of operation for the perimeter lighting feature:
Mode 1:
The perimeter lighting feature is disabled.
Mode default
The perimeter lighting feature is enabled.
Remote Activation Verification
The following are the modes of operation for the remote activation verification feature:
Mode 1: Default
The remote activation verification feature is disabled.
Mode 2:
The horn chirps when the LOCK button or the UNLOCK button on the keyless entry transmitter is pressed.
Mode 3:
The exterior lamps flash when the LOCK button or the UNLOCK button on the keyless entry transmitter is pressed.
Mode 4:
The exterior lamps flash and the horn chirps when either the UNLOCK button or the LOCK button on the keyless entry transmitter is pressed.
Programming Features
Enter Programming
To determine which programmable mode the vehicle is programmed to or to program the vehicle to a different mode, perform the following actions:
Turn the ignition to RUN.
Close all of the doors.
Apply the brakes.
Important: During this procedure, the automatic door Lock and Unlock functions will operate as defined by each mode listed previously, providing the driver with feedback of the current operating mode. If cycled beyond Mode 4, the vehicle will enter operating Mode 1. When the door lock switch is released, the vehicle will remain in the most recent operating mode.
Continue with the following steps in order to personalize the automatic door locks:
Press and hold the driver side power door lock switch.
Shift the transmission out of PARK and then back into PARK.
The vehicle will remain in the current mode and react according to the current mode settings (see Automatic Door Lock modes above).
Cycle the transmission again in order to advance to the next mode. Again the vehicle will react according to the mode settings.
Continue to cycle the transmission until the desired mode is reached.
Delayed Headlamp Illumination
Continue with the following steps in order to personalize the delayed headlamp illumination feature:
Press the driver side power door lock switch.
Cycle the headlamps ON twice and then back OFF.
Release the driver side power door lock switch.
Press the driver side power door unlock switch.
Release the driver side power door unlock switch.
The chime will sound once if the delayed headlamp illumination feature is disabled. The chime will sound twice if the delayed headlamp illumination feature is enabled.
Delayed Locking
Continue with the following steps in order to personalize the delayed locking feature:
Press and hold the driver side power door unlock switch.
Shift the transmission out of PARK and then back into PARK. The chime will sound a number of times equivalent to the mode number.
Cycle the transmission again in order to advance to the next mode. Again the chime will sound a number of times equivalent to the mode number.
Perimeter Lighting
Continue with the following steps in order to personalize the perimeter lighting feature:
Press the PANIC button on the desired transmitter.
The vehicle will remain in the current mode. The chime will sound a number of times equivalent to the mode number.
Press the PANIC button on the desired transmitter again in order to advance to the next mode. Again the chime will sound a number of times equivalent to the mode number.
Continue to press the PANIC button on the desired transmitter until the desired mode is reached.
Continue with the following steps in order to personalize the remote activation verification feature:
Press and hold the driver side power door unlock switch to personalize the remote unlock verification.
Press the UNLOCK button on the desired transmitter.
Press the UNLOCK button on the desired transmitter again in order to advance to the next mode. Again the chime will sound a number of times equivalent to the mode number.
Continue to press the UNLOCK button on the desired transmitter until the desired mode is reached.
Press and hold the driver side power door lock switch to personalize the remote lock verification.
Press the LOCK button on the desired transmitter.
Press the LOCK button on the desired transmitter again in order to advance to the next mode. Again the chime will sound a number of times equivalent to the mode number.
Continue to press the LOCK button on the desired transmitter until the desired mode is reached.
Exit Programming
The following list of events will cause the programming sequence to be terminated:
The ignition is moved from the RUN position.
A door is opened.
KEYLESS ENTRY SYSTEM DESCRIPTION AND OPERATION
The keyless entry system is a supplementary vehicle entry device. Use the keyless entry system in conjunction with a door lock key. Radio frequencies or discharged batteries may disable the system.
Keyless entry allows you to operate the following components:
The door locks
The rear compartment lid release
The illuminated entry lamps
The panic alarm (instant alarm)
The keyless entry system has the following main components:
The transmitters
The remote control door lock receiver (RCDLR)
The RCDLR communicates with the body control module (BCM) through the keyless entry serial data circuit. When you press a button on a transmitter, the transmitter sends a signal to the RCDLR. The RCDLR sends a request to the BCM and the BCM performs the appropriate function.
Dec 10, 2008 at 5:59 AM
