2000 Buick Century Crankshaft Pulley Ring
80,000 MILES • 6 CYL • FWD • AUTOMATIC
HANKQ714
The pulley ring that is around my crankshaft came off. Just the ring that is aroung the harminic balancer(?). Not the entire assembley. There is no slot for a woodruff key on it. Do you know if this is a press fit that I can compress by useing the main bolt or is there another piece that holds this ring in place.
Thanks for your help.
Jan 22, 2009 at 2:27 AM
2CARPRO JACK
  • 11,533 POSTS
That outer ring is vulcanized to the balancer (center hub) you will need to replace the entire harmonic balancer
Jan 22, 2009 at 2:34 AM
DOCFIXIT
  • 18,828 POSTS
Hi If I am following you correctly it is not the pully belts ride on but a ring maybe 3/8/ to 1/2 inch thick that is around a bigger piece that is bolted to crankshaft. If this is correct that ring is part of harmonic balancer it is held on by a rubber insulator to absorb harmonic pitch created by piston detonation. And you will need to replace the balancer.
Let me know
Thanks for Donate
Jan 22, 2009 at 2:41 AM
