Just had resistor replaced. Heater motor runs only in high.
Tuesday, December 9th, 2008 AT 8:20 PM
BUDDYCRAIGG
MECHANIC
GM also uses a relay in the circuit.
The relay switches one way for the lower speeds that go through the resistors, and then switches the other way for high speed so you have direct battery power.
