1996 Buick Century leak inside car under passenger side
USUALBODY
  • 1996 BUICK CENTURY
  • 6 CYL
  • 11,100 MILES
I noticed a leak coming from under the glove compartmnet. Is seems to be anti freeze. But the car seems to have enough coolent in engine no over heating. It is a small drip but has left about cup worth. Is there two systems. What is it
Tuesday, May 19th, 2009 AT 3:47 PM
ZACKMAN
  • 4,202 POSTS
It is your heater core. You will notice small leak (little by little) and your engine won't overheat from that. But eventually you will lose all antifreeze if you don't keep checking and adding the antifreeze. You will eventually will need to fix that before the weather gets cold again.
Tuesday, May 19th, 2009 AT 7:49 PM
