1996 Buick Century
WSLY91
  • 1996 BUICK CENTURY
  • 6 CYL
  • FWD
  • 21,000 MILES
I have a 1996 buick century that has 210,000 miles and it had a fuel leak when I bought it. I fixed the fuel leak by replacing the fuel pump assembly and then I replaced the fuel filter assembly. After that the car would start and idle but it dies after three seconds. When I touch the gas pedal the car either dies or it revs and runs bad then it back fires some times. So I replaced the spark plugs but that didn.T help. Is there anything else I can try?
Thursday, November 5th, 2009 AT 1:05 PM
  • 109,885 POSTS
Has the check engine light come on? Have you checked fuel pump pressure? Vacuum leaks?
Friday, November 6th, 2009 AT 7:14 AM
WSLY91
Yes the check engine light has been on since I got the car. It has fuel pressure. And we checked the vacuum lines as much as we can see of them and we didn't find any leaks.
Friday, November 6th, 2009 AT 12:43 PM
  • 109,885 POSTS
If the light has been on, there will be a trouble code stored in the computer that will help us determine the problem. Take the car to a nationally recognized parts store and have the scan the computer for codes. Most will do it for free. It will help us determine the problem.
Friday, November 6th, 2009 AT 1:37 PM
WSLY91
I have no way to get the car there because it won't run for more than three seconds
Friday, November 6th, 2009 AT 1:47 PM
  • 109,885 POSTS
Call them and ask if they will lend or rent a scanner to you.
Friday, November 6th, 2009 AT 3:38 PM
