1995 Buick Century Lights out
SALEEMAH
  • 1995 BUICK CENTURY
  • 6 CYL
  • 120,000 MILES
My brake, park, lights on my car do not work. Not even the inside lights. However, my radio works but my clock is off schedule everytime I turn off my car. It may be the radiator gone bad. Or, could be a fuse. I don't have any money to fix that piece of junk. And I need my car. Help.
Monday, June 23rd, 2008 AT 8:53 AM
JDL
  • 16,098 POSTS
Do the high-mount brake lites work, they are wired a little differently than the other brake-lites? Are the bulbs ok? The high-mount brake lite gets voltage from the brake-lite switch. The brake-lite switch gets voltage from the stop/hazzard fuse 20 amp. Not only check the fuse, check one of the terminals where the fuse plugs in, it should be hot all the time, you can use a test-lite to check for voltage.
Monday, June 23rd, 2008 AT 10:45 AM
