1994 buick
ACTAFOOL2F
i have 1994 buick century 83000 miles. when i start the car and when its cold it will idle rough and it wants to turn off. idles very low and then speeds up and the again untill it worms up a lil bit. And when taking off from a dead stop it jerks it goes slow but once it starts movin over 5-10 mph it will work fine.
i have no idea what it could be
Oct 29, 2007 at 10:54 AM
2CARPRO JACK
  • 11,533 POSTS
Have you ever tuned it up? fuel injection service? Is the check engine light on?
Oct 29, 2007 at 10:57 AM
ACTAFOOL2F
the check engine light is not on, i used injector cleaner from auto zone but it was never fully serviced, and tune is good
Oct 31, 2007 at 5:57 AM
2CARPRO JACK
  • 11,533 POSTS
Those engines had some injector problems. Try measuring the resistance across them all cold, then warm the engine up and do it again. A fuel pressure bleed down check might not be a bad idea
Oct 31, 2007 at 6:52 AM
