1993 Buick Century fuses
14,789 MILES • 6 CYL • 2WD • AUTOMATIC
THOR57033
my raido, doo locks and ho wn' work. i tested all my fuses in the glove box and replaced the 10 amp for the raido but this did not fix the problem. what else could be the probem evrything else works in the car except thoes items.
Jul 4, 2008 at 12:43 AM
JDL
  • 16,098 POSTS
Some of the circuits you listed, may have more than one voltage source. One voltage source they all have in common is the ctsy fuse 20 amp. Not only check the fuse, check the circuit where the fuse plugs in, that circuit should be hot all the time. Usually the fuse has a bare spot on top for each leg of the fuse. You can use a testlite there, without pulling the fuse, or you can pull the fuse to check the circuit, doesn't matter.
Jul 4, 2008 at 6:54 AM
