1992 Buick Century tension pulley
CRAIG61727
  • 1992 BUICK CENTURY
  • 6 CYL
  • FWD
  • 101,092 MILES
I was told my tension pulley is bad in my buick century and I have the new piece and was wondering if you had instructions on how to put the new one on and take the old one off
Thursday, October 1st, 2009 AT 11:47 AM
JALOPYPAPA
  • 467 POSTS
If it's just the pulley, it's easy; you just remove the nut at the center and pop the new one on. The tensioner, however, which I what I suspect you mean, is a good deal more involved, since it's integral to a large bracket that also supports the power steering pump and half of the alternator. After removing the belt and those two components, you'll see main bolts at the top and bottom of the bracket/tensioner, which is a kind of vertically elongated diamond shape. The trick for the power steering pump is three bolts accessible through the holes in the pulley.
Friday, October 2nd, 2009 AT 4:46 AM
Related General Content
