The car stalls out after it runs awhile(about 12 miles). It will start up in park or neutral, but it will stall again as soon as you put it in gear. It does this about 5 or 6 times then it will run okay for a little while and then do it all over again. Also, sometimes after it starts running again, pressing the gas pedal causes a grinding sound. We checked the fuel pump and its putting out proper pressure and no codes will come up when you check the codes. We also replaced the cadillac converter.
Mar 15, 2008 at 1:06 PM
