1991 Buick Century Starts runs for a few seconds shuts off
BR1SXE
  • 1991 BUICK CENTURY
  • 6 CYL
  • FWD
  • 63,000 MILES
Turn the key it will start right up an run great for a few seconds an shut off.
Saturday, April 25th, 2009 AT 10:29 PM
Check the fuel pressure to make sure its within specs and comeback with the pressure readings we start here
Saturday, April 25th, 2009 AT 10:38 PM
BR1SXE
45psi with engine off and 35psi with it running witch is within specs.
Monday, April 27th, 2009 AT 8:06 PM
Is this a 3.3L engine?
Monday, April 27th, 2009 AT 8:16 PM
BR1SXE
Yes 3.3 fuel injected, took reading from test port on the fuel rail
Tuesday, April 28th, 2009 AT 12:16 PM
Regulated fuel pressure should be 41-47psi
Tuesday, April 28th, 2009 AT 4:56 PM
KEEMOSAABI
Im not a mechanic but it almost sounds as if the car will start shut off because possibly your idle is too low and it dies. Just a thought mabey look into it if you havent fixxed it yet
Friday, June 26th, 2009 AT 5:14 AM
