1991 Buick Century
GOPHER_024
  • 1991 BUICK CENTURY
  • 4 CYL
  • FWD
  • 150,000 MILES
It starts just fine but it wont idle. If I hold the gas down it will stay running but its really rough. As soon as I press the gas down my carb starts to smoke. Where do I start
Monday, October 12th, 2009 AT 1:40 PM
  • 109,885 POSTS
First, I believe the vehicle should be fuel injected. Does yours have a carb? Second, when you see the smoke, is it coming out of the (carb) throttle body or around it? Is it actually smoke or fuel vapor / mist? Do you smell anything burning? Has the check engine light come on? Have you checked fuel pump pressure? Did this happen all at once or slowly over time? When was the last tune up?
Sorry for having so many questions, but I need to eliminate things to get to the problem. Let me know.
Monday, October 12th, 2009 AT 8:37 PM
