1989 Buick Century 1989 Buick Century overheating issue
1989 BUICK CENTURY
190,000 MILES • 4 CYL • 2WD • AUTOMATIC
ERACKLEY
I have an 89 buick century with the 2.5L 4cyl engine. It is overheating and I noticed when it was hot that the radiator fan is not coming on. Is this a sensor issue, which was suggested by my local Napa, or is it a fan motor issue, also suggested by Napa? I am not all that savvy with auto repairs although I am fairly intuitive. If it is a sensor problem, where do I find the sensor on this make/model? Thank You in advance for your answer and I look forward to hearing back from you.
Ed
Oct 26, 2009 at 12:40 PM
DOCFIXIT
  • CERTIFIED EXPERT
  • 18,828 POSTS
Sensor rear engine near water outlet. Ground wire if fan comes on then sensor. if no check voltage at fan if none check relay
Oct 26, 2009 at 1:57 PM
